 Publications de la CIPR
Publications de la CIPR Empty
MessageSujet: Publications de la CIPR   Publications de la CIPR EmptySam 17 Aoû 2013 - 12:09
Vu sur le site de la CIPR
Mais peut-être est-ce plus ancien ??
A commander ou télécharger et à lire :
http://www.icrp.org/publication.asp?id=ICRP%20Publication%20115
Publication n°115 sur le radon
Abstract - Recent epidemiological studies of the association between lung cancer and exposure to radon and its decay products are reviewed. Particular emphasis is given to pooled case-control studies of residential exposures and to cohorts of underground miners exposed to relatively low levels of radon. The residential and miner epidemiological studies provide consistent estimates of lung cancer risk with statistically significant associations observed at average annual concentrations of about 200 Bq m-3 and cumulative occupational levels of about 50 WLM, respectively. Based on recent results from combined analyses of epidemiological studies of miners, a lifetime excess absolute risk of 5 × 10-4 per WLM (14 × 10-5 per mJ h m-3) should now be used as the nominal probability coefficient for radon and radon progeny induced lung cancer, replacing the previous ICRP Publication 65 value of 2.8 × 10-4 per WLM (8 × 10-5 per mJ h m-3). Current knowledge of radon associated risks for organs other than the lungs does not justify the selection of a detriment coefficient different from the fatality coefficient for radon-induced lung cancer.
ICRP Publication 65 recommended that doses from radon and its progeny should be calculated using a dose conversion convention based on epidemiological data. It is now concluded that radon and its progeny should be treated in the same way as other radionuclides within the ICRP system of protection; that is, doses from radon and radon progeny should be calculated using ICRP biokinetic and dosimetric models. ICRP will provide dose coefficients per unit exposure to radon and radon progeny for different reference conditions of domestic and occupational exposure, with specified equilibrium factors and aerosol characteristics.
La publication 104 faisait le point sur la mesure
http://www.icrp.org/publication.asp?id=ICRP%20Publication%20104
Pour compléter au niveau de la conclusion :
Il existe des preuves dans les études cas-témoins pour l'exposition résidentielle au niveau européen
Il existe un risque de cancer du poumon, même à des niveaux de concentration de radon moyenne, à long terme, inférieur à 200 Bq/m3.
Le risque cumulé de cancer du poumon jusqu'à 75 ans pour les non-fumeurs est estimée à 0,4%, 0,5% et 0,7% pour les concentrations d'activité du radon de 0, 100, et 400 Bq/m3.
Les risques cumulés de cancer du poumon pour ceux qui ont été fumeurs toute leur vie sont environ de 10%, 12% et 16% pour les concentrations d'activité du radon de 0, 100 et 400 Bq/m3.
michelange
michelange
MessageSujet: Re: Publications de la CIPR   Publications de la CIPR EmptySam 17 Aoû 2013 - 14:37
Intéressant.
A lire aussi Radon and Lung Cancer in the American Cancer Society Cohort:
http://cebp.aacrjournals.org/content/20/3/438.full
Le radon est le second facteur de risque de cancer du poumon. Entre 2 et 12% des cancers du poumon chez les fumeurs et les non-fumeurs lui seraient attribuables. Mais l'implication du radon dans d'autres cancers n'est toujours pas démontrée.
» CIPR, publications OIR
» MCNP : the Godfather
» Rapport CIPR 2011
» Nouvelles publictions de la CIPR
» CIPR 80 ou 98
Forum technique de RadioProtection Cirkus :: Réglementation :: La RP au niveau international-
